05-30-2023 10:06 PM
06-07-2023 04:13 PM
Turning on roaming data worked
05-30-2023 11:08 PM - edited 05-30-2023 11:08 PM
@Lynn50 In the future always start a topic with as much information as possible when asking your question, without providing any personal information since this is a completely open forum for all to see, it helps us fellow customers give the best advice we can to help out, vague topics lead to confusion.
05-30-2023 10:30 PM
If you are in Canada, you need to purchase Add-on for the country you are trying to call or text.
If you are in the USA now, you need to purchase a US Roaming Add-on then connect to T-Mobile network while you are down in the USA.
05-30-2023 10:18 PM
HI @Lynn50
if you are talking about Long Distance add-on you can only use it to call these counties from Canada
Australia, Austria, Bangladesh, Brazil, Chile, Colombia, Czech Republic, Denmark, France, Germany, Greece, Iceland, Ireland, Israel, Italy, Japan, South Korea, Malaysia, Mexico, Netherlands, New Zealand, Norway, Peru, Poland, Portugal, Puerto Rico, Romania, Singapore, Spain, Sweden, Thailand, Venezuela.
05-30-2023 10:17 PM
Hi @Lynn50
are you talking about US roaming Talk & Text?
or you are talking about Long distance to other country form Canada?
if about Long distance from Canada, which country you were trying to call?
05-30-2023 10:17 PM - edited 05-30-2023 10:17 PM
@Lynn50 Is it possible you used it all check your add on usage
Check add-ons /mins /Data
05-30-2023 10:15 PM
HI @Lynn50
T-mobile is US roaming partner
if you are talking about US roaming, you will need to try to connect to it
But if not about US roaming, you can ignore it
05-30-2023 10:15 PM
Not data add on. Just talk and text. I made one long distance call but haven't been able to make any since
05-30-2023 10:15 PM
@Lynn50 T mobile is the network you want to be connected to if your in the US
05-30-2023 10:14 PM
What is T mobile? How do I check it?
05-30-2023 10:12 PM - edited 05-30-2023 10:12 PM
@Lynn50 Is this a US roaming add on , if so reboot the phone still and make sure your connected to T mobile
05-30-2023 10:11 PM
Hi @Lynn50
Data addon?
Login My Account again using Incognito/Private/Secret mode to make sure the data addon or other addon you looking for is really on your My Account (they are not used up)
try reboot the phone
check if you have data limit set on your phone
05-30-2023 10:06 PM - edited 05-30-2023 10:08 PM
@Lynn50 Try rebooting the phone and make sure you have cellular data on
add check that you still have add in data
