11-04-2019 03:48 PM - edited 01-05-2022 07:51 AM
Hello, I just purchased an add-on that inlcudes the 500-min Canada wide long distance calls. I paid with the same credit card on file. Does this automatically apply to my current plan? Thank you for your help.
11-04-2019 04:04 PM
@ahosu , you should see the purchased add-on in your account. The minutes from your monthly plan will be used up first before tapping into these add-on minutes.
11-04-2019 03:54 PM - edited 11-04-2019 03:55 PM
@ahosu wrote:Hello, I just purchased an add-on that inlcudes the 500-min Canada wide long distance calls. I paid with the same credit card on file. Does this automatically apply to my current plan? Thank you for your help.
Yes it will be added to your account and as long as you have talk in your plan, you will be able to use the add-on minutes when you run out of limited plan minutes, or you are on a province wide minute plan and need to make a call outside of your province.
One other thing is these add-on minutes will roll over every month until used up.
11-04-2019 03:52 PM
You need to purchase and add it to your account.
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-through-self-serve
