Add-On not working
kat8
I purchased a US roaming package a few hours ago and it still is not working. Can you please help me? The payment went through, I tried rebooting my phone a few times, I am in a different country.
9 REPLIES 9
DennyCrane
Do you have data roaming enabled on your phone?
@kat8 then don't wait, message agent and arrange refund
but local data sim and use VoIP app to make calls instead
@kat8  Unfortunately US roaming is hit or miss with US getting rid of  3G … can only try in different areas .. and like already mentioned if it doesn’t work at all request a credit … only other option would be to pick up a local pre paid SIM card for your trip
kat8
I have all that
@kat8  do you have VoLTE enabled on your account or option on your phone to enable it , that may help also
Hi @kat8
turn on VoLTE
and make sure you enable data roaming on your iphonr
kat8
iPhone SE2
Western states
I am on T-Mobile but I cant make phone calls or use data
I dont want a refund, I would like to not be stranded
@kat8  Roaming only works in the US hoping that’s the country your in , make sure your connected to T mobile and reboot the phone as you have already stated , if it just does not work you can ask for refund / credit through support ticket
  • Getting support / submit ticket
  • Get support by starting a conversation with virtual Chat box >>>>>>. Click here
  • Or while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking here.
Hi @kat8
what phone do you have?
which states you are at?
you cannot connect to T-Mobile? try to change to manual connection and pick T-Mobile
for refund, please message cs agent
