05-27-2023 11:58 AM
How do I transfer my esim that installed on a Pixel7 to a new iPhone 14?
There is no option to do this in the app
thanks
05-27-2023 04:26 PM
hi @Bokeh
PM eSim is still a new thing, pretty sure they will upgrade it and you will be able to use the eSIM again
Just give them a bit more time
05-27-2023 04:24 PM
Yes, they confirmed that this was the only way to transfer
05-27-2023 04:05 PM
hi @Bokeh support confirmed there is no way to transfer to another esim phone?
05-27-2023 04:03 PM
Ended up having to buy a physical SIM card and transferred the number to it
05-27-2023 01:06 PM
@Bokeh if the Chatbot is not working, please open ticket via message
05-27-2023 12:21 PM
Looks like I’ll have to submit a ticket. Unfortunately, the ticket system is not loading
05-27-2023 12:06 PM
Here is how to transfer eSIM:
05-27-2023 12:03 PM
ho @Bokeh eSIm is still very new to ever, I think you need to open a ticket with support at
