Active account but send code to wrong phone number
Jasonzhang
Hi there,
I just actived my account and got a new phone number. But when I log in my account. The system asking my the one time code from message. However the *******598 is not my phone number. Therefore I can not access my account. Hope I can get the answer to solve it.
Thanks,
Jason
will13am
@Jasonzhang , have the 2FA code sent to email as already suggested.  Once you get into the online account, change the eversafe profile to your new number.
@Jasonzhang  If after trying what’s been mentioned doest work you can use this direct link to support to help you regain access
send a  private message   To CS_Agents click
hycm53
@Jasonzhang wrote:
Hi there,
Thanks,
Jason
Click resend code on log in page, then select send code to your email.
JRod
@Jasonzhang
If you clear the cache/browser data, and then try to re-login on an incognito window does it still tell you the wrong number?
Trying to access your account with another browser or with the app might be worth trying also.
I am assuming you’ve fully gone through the activation process with the app?
