Activation
11-29-2024
01:35 PM
11-29-2024
03:01 PM
computergeek541
Hi all, I think I have submitted ok but how do I know? How do I know when its done, and when should I put my sim card in. Thank you
Joining Public
11-29-2024 02:42 PM
@Tonygl, if you are transferring in an existing number from another company you will need to leave the old SIM card in your phone until you have received a text message from your old company confirming that you want to port out your number. When you get this message you will have 90 minutes to respond "YES". After that, you can remove the old SIM card and install the Public Mobile SIM card into your phone. Test every 15 minutes or so to see if you can call your number from another phone. When your phone starts to ring the porting process is likely done. At that point you should test calling out, sending text out and receiving and test your data. It usually take 1 to 2 hours for the whole process to be completed.
11-29-2024 01:37 PM
hi @Tonygl
did you request porting the number?
But first put in the PM sim card first. Test if it connects, if you can make outbound calls. Check if data works
finally check if you receive inbound calls
