04-25-2022
12:12 AM
04-25-2022
12:19 AM
computergeek541
My new iPhone XS Max is asking for an activation code and it's not reading my sim card, Can anyone help Me?
04-25-2022 06:39 AM
@melneddow85 - does your Public Mobile SIM card work in another device with issue? Just getting that part out of the way?
For this particular phone, you may need to contact the seller or former owner.
Have a read through this article about what sounds like you are experiencing:
https://www.businessinsider.com/activation-lock
04-25-2022 12:41 AM
Sound alike a device issue, I've heard this happening with iPhones, I can't recall similar issue with android
04-25-2022 12:23 AM
If everything is on the up and up then....
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-25-2022 12:19 AM - edited 04-25-2022 12:20 AM
Your SIM card previously was in your old phone and working perfectly normal with pm services? Was your old phone an iPhone as well? Did you you connect to WiFi or iTunes and check for any software updates and update the carrier profile to public mobile? What is the exact message you are getting from the phone?
04-25-2022 12:18 AM
@melneddow85 wrote:My new iPhone XS Max is asking for an activation code and it's not reading my sim card, Can anyone help Me?
To me, this doesn't sound like a Public Mobile issue. iPhone devices ask for these codes to make sure that you own the device. Where did you get this phone form?
