04-07-2019 08:02 AM - edited 01-05-2022 04:12 AM
Hello,
I registered my SIM and plan on April 4th, after verifiying my phone would work (CAT S40) on Public Mobile. I am still waiting to be able to use it..
I have even tried the SIM in another phone just to make certain.
Phone still shows no service, I have powered it down several times over the last couple of days. Very frustrated.
04-08-2019 03:08 AM
@NorthernOwen wrote:Hello,
It sounds like you're trying to port a number.
Since you've tried it in more than one phone, it's most likely your number is still being ported.
Contact a mod through a private message (be sure to include your old account information) and have them work on it for you.
04-07-2019 04:43 PM
The service should have started immediately working after activation.
To my knowledge, Cat devices have always been sold as unlocked. Do you have the North American varaint of this the S40? Where did you buy it from?
There are 2 versions of the Cat S40 according to the manufactuer's website, one far more ideal than the other.
04-07-2019 09:15 AM
I had the same issue the problem was with porting my number, you have to contact the moderator.
04-07-2019 09:09 AM - edited 04-07-2019 09:11 AM
Have you sent a private message to the moderator? They will be able to look into your file and see if there's any issue. Additionally, are you porting a number or using a new number. If you're porting a number, PM might be requiring more information to port the number which is causing the delay.
04-07-2019 08:04 AM - edited 04-07-2019 08:07 AM
Just to be sure did you check with willmyphonework? And is your phone unlocked from your old company? The problem is not your sim (if you tried it in the other phone and it WORKED)so it's your phone now...
