Activation Not Working
MelissaCV
Trying to transfer to Public Mobile, got to step 6, but it won’t activate.  Had this same issue with my daughter’s phone last fall and a Public Mobile rep said the issue was on their end.  Now, I can’t get in touch with Public mobile to fix the issue.  Any suggestions?  Thanks
2 REPLIES 2
MelissaCV
Thanks, I’ve done both, appreciate it
hi @MelissaCV
yes , we saw a lot and they all turn out need agent to step in
Please submit a ticket with CS Agent using this Chatbot if you can login My Account.        https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
