Activation Issue with Eversafe
BJR56
I was going through activation.M
Finished SIM registration and selecting a phone number.
Get challenged with unknown device and the code is sent to the phone number I selected but it is not activated... it receives no code... so now I am stuck... can't get in.  Phone does not appear to have finished activation (it was in the last step).
@Dublicate_acct wrote:
Also of interest may be if persons that have encountered problems since the switch would post the problems they are experiencing and hopefully the solutions .
@Dublicate_acct - regarding your statement above...umm, just search the Community, you will find tons of issues posted.
But even before this May 2023 update there have been lots of issues posted in the Community about Self Serve, rewards, plans, etc. you name it.
As for your questions about why switching to EverSafe....us members can only guess as to why Public Mobile changed to EverSafe, improved security, reduced sign in credentials, ease of verification, etc.  We are only customers and members like you here, remember?
@BJR56  We happy to hear it . Welcome to public mobile 🙂
BJR56
worked, thanks so much!
@BJR56  So, you got passed the phone number selection or porting part yet?  You picked porting in phone number?
if so, did you get the porting authorization text from your old provider?
@BJR56  First try rebooting the phone . If no dice hit resend code a free times . And you should get an option to send code to email instead . Give that a try if still no luck pleas submit ticket with support
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
