07-20-2023 10:38 AM
hi
I unsubscribed to this account last month. Never did register autopay.
This month my credit card it being charged and i am now subscribed again? How did that happen?
My Account
08-01-2023 08:21 AM
Thank you
08-01-2023 08:21 AM
Thank you very much. I will await the charge back. Thanks for processing the charge back.
07-20-2023 01:08 PM
Depending on when you first signed up, autopay gets turned on automatically. You would have had to have manually turned it off. So maybe you did. Good. Was that before this new system came in. I think we have seen a few of these when the new system came in and suddenly suspended accounts were restarted.
I would do a chargeback.
07-20-2023 11:59 AM
HI @mama3
it should work as it was done by agent
Reply and ask to confirm
and login My Account using Incognit/Private/Secret mode to double, triple check if the Subscribed option is now disabled
07-20-2023 11:59 AM
hope this works this time around. i tried last month and same issue. i sent a message to CS and Nick as well. if someone can advise me when it is done would appreciate, because i have contacted my bank as well. let me know
07-20-2023 11:56 AM
I hope this works this time around. i tried last month and same issue. i sent a message to CS and Nick as well. if someone can advise me when it is done would appreciate, because i have contacted my bank as well. let me know
07-20-2023 11:35 AM - edited 07-20-2023 11:36 AM
You better check all your credit card statements because PM is a online self-serve format and communication is all done online.
How did “Nick” contact you?
07-20-2023 11:33 AM
07-20-2023 11:29 AM
i tried to get someone to delete the credit card information. I once again unsubscribed. Used the link , then VVVV, someone by the name of Nick . Is this correct?
07-20-2023 11:08 AM
07-20-2023 10:47 AM
@mama3 Make sure auto pay is turned off like this
Turn auto pay OFF/ON 3 easy clicks
Or if you know the 4 digit PIN number
*611
or you can get support to remap e credit card I for right away
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
