Account problem
Evi
I changed my subscription while I was in the usa.  Now I am back it seems to think I live in the US.
will13am
@Evi , did you put your phone on manual network connection?  Switch the setting to auto connect and the phone should be able to find and connect to the Public Mobile network.  Try to avoid doing unnecessary resets which causes huge inconveniences.
@Evi  Maybe try resetting network settings . This will of course erase any saved wifi password . You just have to re enter it again .but you should se public mobile in the top of your phone
hairbag1
@Evi
huh ? How does it show that ?
