06-21-2023 01:58 PM
Hi there,
One of my public mobile accounts is locked. Every time I try to sign in and even after I update my password successfully, it doesn't let me log in. How do I fix this?
06-21-2023 02:18 PM
HI @Tofu14 It said account locked? you need to wait an hour.
Maybe try on a difference device after.
06-21-2023 02:06 PM - edited 06-21-2023 02:06 PM
@Tofu14 This just happened to me . I had wait the hour . Go to login put in email .forgot password get code sent to email and verify . Create new password. Have another code sent to phone verify . Then I was logged in
06-21-2023 01:59 PM
@Tofu14 wait a full hour before trying to login again
After the hour wait, try to reset password and login on a browser using incognito mode. Or you can try using the app if it still fails
if both tricks do not work, PM support is your friend, please message them directly here
