10-25-2022 08:47 PM
I just switched to PM, both my younger son's I want to bring with me so I can also get the rewards. For some reason my credit card is not working for them , any reason why?
10-25-2022 09:09 PM
it worked ty!
10-25-2022 08:56 PM
I will try that
10-25-2022 08:55 PM
in the credit card field , it does not ask for the name on the CC
10-25-2022 08:55 PM
Clear your browser cache and cookies and go incognito. Make sure you are using a separate email account for each activation.
10-25-2022 08:54 PM
It should work, @hockeybonkers . The same payment card can be used for many accounts, if desired. I use it for 4 accounts.
If it is being fussy, wait 1/2 hour, clear cache and cookies, open an incognito tab, then try again.
Be sure to manually enter all the information, ensuring all fields are accurate.
