a week ago
I got my account activated but phone had technical issues and wouldnt connect then ended up getting new account activated with Koodo on day 2 of public mobile account however my public mobile account was deleted without my consent how do I reactivate it ?
Wednesday
Thank you for the escalation! The customer is in contact with an agent.
a week ago
@Mark740315 wrote:The number was not ported and I’d it was then I want a refund seeing as the account was never working so someone from support better contact me soon Ive been trying to get back into my account since I read the transfer to Koodo link i didnt even complete the application for Koodo and already they deleted my PM account access
HI @Mark740315
PM won't issue refund most the time. But if account was never worked before, then you can ask PM to reconsider. Please message support using the link provided above.
And since both Koodo and PM are owned by Telus, so ask Koodo and they might be able to issue a one time credit to cover your lost
a week ago
a week ago
hi @Mark740315
not sure if you have created a new Koodo account after or if you ported your number to Koodo after you failed activating with Public Mobile. If you ported back to Koodo, then yes, the account would have been closed. This is the usual procedure for all porting request. Your Yes reply will allows the number to be ported as well as closing the account. So, it is actually correct that your account was closed if you ported your number to Koodo.
But if you like, ask PM agent to confirm, you can submit ticket by direct message:
(and sorry, PM won't issue refund. But both Koodo and PM are owned by Telus, so ask Koodo and they might be able to issue a one time credit to cover your lost)
a week ago
Don't worry, this is completely normal and means your port was successful!
In Canada, wireless number transfers are designed to work like a single-line domino effect. Because Public Mobile accounts can only hold one phone number at a time, the exact moment Koodo successfully pulled your number over, Public Mobile was legally required to shut down that line.
Since there was no other phone number attached to your account, the entire account automatically closed.
a week ago - last edited a week ago
when you said "new account activated with Koodo on day 2", did you port your number from PM to Koodo?
Either way, you can need to sort this out with PM support, generally, you need to open ticket with PM support
But I have escalated your ticket on your behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
a week ago
@Mark740315 wrote:I got my account activated but phone had technical issues and wouldnt connect then ended up getting new account activated with Koodo on day 2 of public mobile account however my public mobile account was deleted without my consent how do I reactivate it ?
Hello @Mark740315
Once you port your number to another provider, your account is automatically closed. Standard procedure.
