OnePlus phone
sthadks
I was planning to buy One Plus phone with 5G connectivity and both the IMEI number shows not compatible. Not sure why even new devices with 5g are blacklisted by carriers.
IMEI not compatible meaning $5 is charged monthly even for devices with 5G?
Dunkman
@sthadks
According to PM, it is actually the phone manufacturers that need to turn on VoLTE for a specific mobile carrier. Since Public mobile only introduced VoLTE since 2022, their whitelist of phones is smaller than other mobile companies include parent Telus and Koodo which introduced VoLTE much earlier.
Owners of One Plus phones should try to contact phone manufacturer to try to convince it to expand VoLTE compatibility to PM customers.
To providers, OnePlus still considered as an imported phone (that's why none of the Big 3 providers selling OnePlus)
sthadks
@slusagm - One thing I am little confused about Publicmobile Telus is that why are latest phones with 5G 4G like OnePlus, Oppo not whitelisted and supported for VOLTE? To be honest, OnePlus has always been my first choice besides Samsung, Moto, Google and Iphone. With this rule or policy from carrier does it mean I have to give up the phone that I like to the cell phone companies which I really dont like 😃
@sthadks One Plus 12R does not even pass the Telus IMEI test, so it won't be compatible here.  I would avoid
Honest, at this point, it is safer to stay with  Samsung , Moto, or Google if you want an Android phone
sthadks
Thank you @softech , I currently have One plus 7T and was looking to buy One Plus 12R[International verison]
@sthadks
It is not whether a phone is 5G or not.  The problem is a combination of 3G shutdown and the lack of VoLTE compatibility
While your One Plus phone has 5G and VoLTE, it is NOT compatible with PM's VoLTE network.  You can use the  IMEI checker on this page to confirm:  https://www.publicmobile.ca/en/on/get-help/articles/volte
Since your phone is not compatible with PM's VoLTEyour phone has been using 3G for voice, but is now affected by the 3G Network Shutdown that has just started in Manitoba:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
If you’re using a 3G-only device, your phone will stop working after these dates:
Manitoba (Rural): January 12, 2026
Manitoba (Urban : Winnipeg & Brandon): Starting March 31, 2026
National: Starting March 1, 2027
There is really nothing much you can do other than to get a phone that is compatible with PM's VoLTE network.
iPhones 8 or later, Google Pixel 4 or later, Samsung S22/Flip 2/Fold 2/A15/A35/A55 or later, or other major brands of phones released after 2024 and are designed and sold for the Canadian market should work.
If you are unsure whether a particular phone will work, share the model here and we can help
