02-04-2023
12:31 PM
02-04-2023
12:49 PM
computergeek541
How can I find my account number if I am locked out of My Account and have been on autopay (i.e., have no bills with my number)? I have found my initial activation email from PM and it does not list such.
The help people are not helpful as they require my account number to verify it is me, and when I tell them I do not have that, they say I need it.
It's a circular disaster and I need my account number so I can change companies.
Thanks,
02-04-2023 12:44 PM
People answering questions here should carefully read what was already posted. I see more and more either wrong or sometimes already given answers. I know that sometimes those are not posted yet, but at least read carefully what OP said.
As for your @Shelby4 problem, while it is frustrating that you cannot login and you are the owner, you need to understand that support doesn't know that and needs proof. Anyone could come and say, hey, here is my number and I cannot login. Get me access. I think you have 2 options:
1. Reset password (as you do know email you used)
2. Contact CSS and see if there are any other ways to prove you are you, like credit card used to pay or something.
Good luck
02-04-2023 12:44 PM
Yes, that's the one. Not sure why the other user is insisting so hard on needing support to find the account number when you have it right there.
02-04-2023 12:42 PM
02-04-2023 12:40 PM
@Shelby4 as mentioned above, you need to open ticket with PM support using direct message . You can work with support on the fraud situatoin.
but if you need the account number for porting out, you still need to get the account active first. ONLY active account can be ported out of PM
02-04-2023 12:40 PM
@dust2dust 1000000229345X? (hidden last number)?
02-04-2023 12:40 PM
To find your Account number, search your most-used e-mail accounts for this e-mail header, which also contains your PM Account Number beginning with the 100000 sequence of numbers:
02-04-2023 12:39 PM
Yes they're rather sensitive about chargebacks.
Since you have your welcome email, can you open up the headers or source of the email? The account # should be "hidden" in the To: area. It will be a 1 followed by a bunch of zeroes.
A lot like this:
Received: from unknown (HELO RKDYNCRM1) ([96.1.138.227]) by orkaan-i.nssi.telus.com with ESMTP; 18 May 2018 03:50:10 +0000 MIME-Version: 1.0 From: "Public Mobile" <[email protected]> To: "100000########" <my email address> <<<--- Date: when I signed up
02-04-2023 12:38 PM
@Handy1
Right but again, I cannot access my account, so I cannot see this screen. As said, I have sent a ticket and they require my account details to release account details.
02-04-2023 12:37 PM
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you supports help
Watch for reply top of page to the
Right ( envelope image )
02-04-2023 12:36 PM - edited 02-04-2023 12:36 PM
@softech I have. They require my account number to give me access to any account details.
02-04-2023 12:35 PM
@Shelby4 then you have to message support using direct message
02-04-2023 12:34 PM
They have banned my from My Account because of a fraudulent charge. I cannot access and they will not provide access.
02-04-2023 12:33 PM
@Shelby4 yes, you can find account number from Profile page in My Account
Understand you cannot login, try to open ticket with PM Support for help for the login issue
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
