Account Number
BINHNAM
Hi I need help getting my account number but I have no access to my online account.
hi @BINHNAM check if you get any email from PM when you joined, there could be account number in the Welcome email
if you cannot find it, then you will need access to My account and get it from there
To get access back to My Account,  please open ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Quigley
@BINHNAM
To get access to your account you'll have to get help from a Customer Support Agent.
Use the Chatbot Simon to get a service ticket started first.
Or send a private message to CS_Agent
@BINHNAM try to use the Reset Password link there.  out in the possible email address used
if that does not work, PM support is your friend, please open ticket via Chatbot
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or if you have trouble with Chatbot,  Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@BINHNAM @Try logging in again in incognito mode there’s is cache issues
