Acc suspected unexpectedly
golodv
Hi there.
Today should be auto top up, but it did not happened. And service stopped.
No problem with card for auto top up. I checked.
What should I do next?
8 REPLIES 8
golodv
Thank you! Its really helped.
golodv
Yes, I used it, but I did not find such button there. I will try to use links maybe.
@golodv
you can make a manual payment on the the following page. Load enough funds and account should renew itself
https://myaccount.publicmobile.ca/en/account/payment/funds/card
And if you need to reset your account PIN, please use this link
https://myaccount.publicmobile.ca/en/account/reset/pin
HI @golodv
did you try using the PM app? see if you have such button on the app
golodv
Where I can find public mobile account PIN? I have no SIM
golodv
Sorry, I can not find button Pay and Resume. I changed my payment card and have no clue what will be next. But still no service.
Meow
If autopay did Not work for you for whatever reason try adding funds manually and then force payment.
hi @golodv
yes, autopay will fail sometimes.  In such case, you need to make a manual payment
 login again using Incognito/private/secret mode on your browser. See if there is a button Pay and Resume service. Click and pay
