04-19-2018 10:59 PM - edited 01-04-2022 04:08 PM
04-20-2018 04:14 AM
wondering if your credit card company see the transaction declined or error on their end?
sometimes it helps that way.
04-19-2018 11:45 PM
Like I say when I was activating my sim it froze after the last step. I had already put in all my payment info and everything. When I tried again in incognito mode it said another member has reserved the sim number and I couldn't input it for 1 hour. I'm not sure if it was 1 hour from when I closed the frozen window or there was only 1 hour left when I tried again because it was frozen for several hours before I tried closing it
04-19-2018 11:33 PM
As long as the activation process does not go too far, the SIM will not be registered in the system and be rendered unusable in a subsequent activation attempt. Being unable to progress past the payment step should mean that nothing has happened and everything is reversible.
04-19-2018 11:17 PM
When I first tried signing up it froze and said leaving the page could cause problems but after waiting hours and reading other posts on this community I just closed it and restarted in incognito mode. I had to wait an hour before it would allow me to try activating the sim again but it all worked fine after that. Obviously I can't guarantee nothing with go wrong for you but I think that's your best chance if you want it for tomorrow
04-19-2018 11:12 PM
Hi. I can't try incognito, because i havent been able to complete my acocunt yet.
If I try again, I'll have to try to activate SIM again, which might screw everything up, then try to find the phone number again...
04-19-2018 11:09 PM
Unfortunately the mods have gone home for the day.
The only thing I can recommend is clearing your browser history/cashe otherwise use google chrome incognito mode
04-19-2018 11:04 PM
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
How can I view my private messages between myself and a Community Moderator
