8b1 call error
chimijen
I went to call my family doctor to realize that I kept receiving the 8b1 "your call cannot be completed as dialed" error. Yes I took the SIM out and put it back in with phone both powered off and powered on (didn't work). Yes I tried to dial it with +1 (506) and without. Yes I tried dialing the number manually. None of the solutions worked, and I cannot get in touch with a single person who knows what this issue is caused by or how to fix it. I have important medications I need to be able to refill via this number, so the fact that I cannot reach it is a huge concern. I can dial other numbers and call other people, but I cannot contact my doctor. From what I've seen, many are having issues contacting crucial health services with PM and I am really hoping I am not one of them. What can I do (that isn't resetting my entire phone)?
chimijen
It is one particular number that is doing it (as far as I know) as I have tried to call a few other numbers just to be sure. I don’t have the option to reset my network settings on my phone, I spent a lot of my time trying to do that fix before realizing it somehow wasn’t possible 😞
chimijen
No, my account isn’t suspended nor is telus down in my area. I am able to make texts and calls to others, but I cannot contact that number. I tried to use CS but it absolutely failed and I couldn’t even put out a ticket, nor did the AI have any idea how to help.
hi @chimijen
is it only one particular number you cannot call and got the error ? or calling all numbers got you the same error?
did you try Reset Network Settings?
if same, ask PM support to help.    submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
@chimijen  And your account is active and not suspended ? Text and data work ?
also check
Outage map in your area:
https://istheservicedowncanada.com/
if account is active and no outage
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
