Issue with eSIM Activation – "eSIM Not Installed" Error
gabort
  • Hello,
I have already subscribed to Public Mobile and I'm trying to activate my service, but I keep getting the message "eSIM not installed" at step 6 of the activation process.
I tried several times, but it still doesn't work.
I'm wondering if I might need a physical SIM card instead.
Could you please help me with this?
Thank you very much!
CSA_PM
Customer Support Agent
Hi @ gabort
Is the service working now?
hi @gabort
usually the eSIM is installed by the app
do you see any Public Mobile eSIM on the Settings -> Cellular screen or the Sim Manager screen?  Check if it is enabled or if Turn on this line is on
TheSterlinger
Hi,
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
'Contact Us', and choose your topic.
If you are not successful with the chatbot,  use the next link below.
