12-02-2024 02:46 PM
I'm having issues applying the 50 percent off promo code. Can someone help pls?
12-04-2024 09:11 AM
Thanks everyone, messaging the cs_agent worked. Had the code applied, will start in the next billing cycle.
12-02-2024 02:58 PM
Thanks for the help! I'll keep the post update. Thanks you two!
12-02-2024 02:48 PM
@TheKid89 Wasn’t aware there still 50% off promo code but you can ask support to help
12-02-2024 02:48 PM
hi @TheKid89
the code might not work anymore .
but you can check with PM support .
submit ticket by direct message:
