10-06-2022
12:06 AM
10-06-2022
12:23 AM
computergeek541
Hello Community,
I received a text message earlier today from public mobile that said my plan renewed on September 21st that I had used 75% of my data.
Usually 3GB of data is plenty for me but to ensure I have enough data I upgraded my plan which shows I have barely used my data.
Plan Usage
Current Plan Cycle: Sep 21, 2022 - Oct 21, 2022
5GB at 3G Speed
4.08 GB left
Not sure why I received this message.
I also have a 1GB of data which shows that 61% has been used.
Add-On Usage
10-06-2022 06:14 AM
Use your data warning and limiter in your phone to help track your usage. I use mine to track my plan data (250mb) so I know when I may start to use my add on data (20gb+).
Public mobile sends out data usage texts at 75% and 95% of all data on your account. These texts won't help me....but by setting your data warning at 25% of your plan any text messages sent by pm before you need to reset
your limiter can be safely ignored.
7Reset the data warning to 75% and the limiter at 95% and they should more or less alert you at the same time as any pm data usage texts (+/- add on data).
10-06-2022 04:34 AM
This could be from a glitch in the system. Just login to your account and it will show your current usage.
10-06-2022 01:41 AM
The warning text message has been often reported as an error received by many others, but double check in the self-serve portal that the usage is current & accurate. To do this, make sure to click the little circle-arrow in the bottom right corner of the "Plan Usage" section -- this should refresh to the latest information...
10-06-2022 12:30 AM
