05-29-2023
10:20 AM
05-29-2023
10:30 AM
computergeek541
Hi there, I don't know why but I can't seem to make certain outbound calls (usually 1-800 numbers). I've recently changed cell phones and brought in the public mobile sim. I just receive an automated recording with "6CU2 - the number you have dialed is unavailble". When I call from a friends phone, the number works and is in service.
Any idea how to fix this issue?
Thanks so much!
05-29-2023 11:06 AM
@aproyalwriting wrote:Hi @esjliv thanks for this. My friend is with Bell. I actually havent been able to call any toll free numbers on this phone for the past two weeks since ive switched the phone. An example is 1-800-654-4173. This is confirmed works with my friend who has Bell and it works in my old Iphone with my same public mobile sim.
@aproyalwriting - I can connect with my Public mobile cell, as well as another provider's cell.
Maybe try a reset of the network settings on your device and see if that helps.
If not, submit a ticket with CSA and ask them why this would be; 2 weeks is a while now. Hopefully it is just a reset of the account or something.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
05-29-2023 11:05 AM
hi @aproyalwriting another customer talked about the 1800 number problem on the weekend. I can call those myself. Maybe a ticket to support is needed if you have it done so
05-29-2023 10:59 AM
05-29-2023 10:47 AM - edited 05-29-2023 10:48 AM
@aproyalwriting wrote:Thanks guys - I wasn't aware of this... So is there any work around? This seems like it will be a real inconvenience....
@aproyalwriting - do you know someone else with public mobile that can test if they can call this number? Or, share it here and i could test it with both public and another provider. EDIT, what provider is your friends?
If it is only you, perhaps this is just temporary, either connected to just being a new customer or the tower near you.
You could try your SIM into another phone, see if it works. then move it back to your phone...sometimes just doing this can help with finicky account issues.
05-29-2023 10:40 AM
Hi there, I do not have it hidden.
05-29-2023 10:28 AM - edited 05-29-2023 10:40 AM
05-29-2023 10:27 AM
Do you have hidden caller id set on the phone?
05-29-2023 10:24 AM
Did you try any other 1-8xx (toll free) number?
Not all toll free number are available through PM.
05-29-2023 10:22 AM
@aproyalwriting Not all 1-800 numbers work with PM
