Resubmit transfer request
Phil0412
Missed initial window
Phil0412
I have called the number several times wit no luck, and have entered the number twice, its always the same response, the transfer does not exist and no one comes on the phone
hi @Phil0412
I have sent you a number to the poring team.  They will re-initiate the port and you wil receive the text on your old sim card.   Please check your inbox for the number
@Phil0412  There’s a number to talk to live support will send you private message to restart port process
