6 GB data bonus question
norulez
Hi,
I am travelling from BC to Alberta this month and wanted to know once my data is used up from my plan (~5 GB left) I would be using my 6 GB data bonus while in Alberta and when I come back to BC before my plan renews. Is that correct?
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
@norulez
Yes, once your Plan data is used up, any addons you have for data will kick in.
Then when your plan renews, your plan data will be the bucket that is being used again (no matter where you are in Canada).
7 REPLIES 7
@norulez
HI @norulez
Yes, data has no border, within Canada.  So, your add-on / bonus data will kick in whenever the regular one runs out
enjoy your trip
norulez
Thank you.
hairbag1
Anytime during your plans 30 days...if you run outta regular plan data...then the bonus data will kick in. If you still have unused bonus data at renewal date...that unused data will roll over until next time you run outta regular plan data.
Timer
@norulez
yes, once your plan data is used all, then your add-ons will roll in.
will13am
@norulez when you have a Canada wide calling plan there's no real difference if you are in the home province of not.
norulez
Thank you
