5G speed issues - please help
Joybellswj1
I am in a 5G coverage area but my phone still shows LTE and I did a speed test and I am only getting 73.73 Dowload MBPS!!  According to the website I should be getting up to 250 Mbps download speeds.
I have an iphone XR and an eSim.
Please help
Thank you!
11 REPLIES 11
Joybellswj1
Thanks, I figured out through other members that the iphone XR is not 5G compatible, boo.
Joybellswj1
Thank you!
Grand_Total
As a number of other posters have already told you your phone does not support 5G (neither does my iPhone XS). However, there is no reason why you should not see 250Mbps if you are in an area where signal is good and the tower is not overloaded. I saw 260Mbps when I ran a test after signing up.
Joybellswj1
Thank you, I didn't realize that.
Joybellswj1
OH!  I did not know that. booo
Joybellswj1
I tried a different speed test website and it was even lower unfortunately
@Joybellswj1
The iPhone XR is NOT 5G compatible. You need an iPhone SE (2022) are newer to get 5G.
Hi @Joybellswj1
Sorry, your phone does not have 5G if it is a XR
However, if you have 5G plan, you should get better speed than 72.   Please try speed test in different places
Actually @Joybellswj1
iphone XR does not have 5G support
TheSterlinger
Hi @Joybellswj1 ,
Please note 5G for iPhones are only supported on iPhone 12 or newer.
@Joybellswj1 which Nework mode settings do you have? 5G Auto or 5G On?
5G Auto will allows iPhone to drop back down to 4G to svae battery most the time when the extra speed is not needed
if you want ot test your 5G, change to 5G On and do a speed test.  But remember, it could drain your battery faster
