5 to 10G Data Change
RogerF
Hi - presently on 5G data at $40 would like to go to 10G for $50.
Have about 3G in promotional data not used.
if I change plans will I LOOSE the bonus data I have.
Thank you
Jordan1111
I believe it carries over.
@RogerF
Changing plans and the possibility of losing a promotional bonus data add on is YMMV however the vast majority of the time a promo data add on stays....a monthly plan data bonus usually is lost.
Do you feel lucky? I would wager on you being successful as I have been in the past with this promo....
And this was a downgrade to the $15 plan.And this was a downgrade to the $15 plan.
Triguy
It depends if the bonus data was part of your plan.  Most add-ons usually will remain in your account until consumed.  If you make a plan change it is recommended to change on next renewal so you any lose any unused minutes/texts or data.
https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
hairbag1
Thank you
Was the 3G data tied to the promo ? Some promo's claim they'll expire if you change plans, but I haven't heard of it happening when you upgrade to a higher cost plan.
