05-25-2019 08:12 AM - edited 01-05-2022 05:04 AM
Is the 5 mb bonus data advertised on the deal for May 25-26 a one time bonus, or do you get the bonus every month?
thanks
05-26-2019 01:11 PM
@Kellypowerkean wrote:Is the 5 mb bonus data advertised on the deal for May 25-26 a one time bonus, or do you get the bonus every month?
thanks
ONE TIME BONUS to be used till it runs out.
if it’s was every month we’d all be moving to 1GB + 5GB for $25/month would be amazing. But sadly one time only. Still a good deal for those who may use slightly more than 1GB or don’t want to worry about using slightly more
05-25-2019 01:39 PM
@scottshepherd00 wrote:If thats the case its similar to Fido’s Data Bytes session 5 one hour sessions per month to use data and its activated in an app OR
Freedom Mobile had a promo on get a bonus 120GB of data to compete with this offer however the fine print stated it was 120GB for one year.
This 5GB data bonus can be used in any way/over any time frrame that you like. This one-time 5GB bonus can be kept for longer than a year. There is no preset expiry time for this bonus add-on.
05-25-2019 01:36 PM - edited 05-25-2019 01:36 PM
thanks
So that you don't need to open up the picture too look through the fine print, the 5GB is a one-time bonus.
05-25-2019 08:31 AM - edited 05-25-2019 08:32 AM
thanks
Thanks @JaimeLaPizza
05-25-2019 08:24 AM
05-25-2019 08:21 AM
It's an add on so when you use all the data in your plan you start taking it out of the bonus 5gb. The 5gb add on keeps rolling over to the next month until its all gone so it can last a long time if you only use a bit out of it every month
05-25-2019 08:15 AM
The bonus stays unless you change your rate plan and is only eligible for new customers signing up with Public Mobile!
