07-08-2018 10:33 AM - edited 01-05-2022 05:04 AM
07-08-2018 02:29 PM
07-08-2018 12:28 PM
you need send a private message to Click here
In your message put it, please include.
- your account number
- your phone number
- your account PIN
- Detailed explanation of specific your issue
- them can help you a lot nice service Team
Good Luck
07-08-2018 11:41 AM
07-08-2018 11:33 AM - edited 07-08-2018 11:33 AM
07-08-2018 11:17 AM
07-08-2018 10:59 AM
@cserif72 for self serve account you need to log in by your email address & password not the username like Community just so you're aware of that.
07-08-2018 10:57 AM
@cserif72 if you remember your PIN, it'll process faster, for account number is not really necessary as long as you have phone number with PM 🙂 when I send them a private message it should take about 3 hours or more to reply
07-08-2018 10:45 AM
07-08-2018 10:38 AM
@cserif72 did you try to reset a password for your self-serve account? You can have a look at this article for Password Reset Procedure https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Password-Reset-Procedure/ta-p/210813
07-08-2018 10:36 AM
I recommend you send a private message to the moderator team and ask them to change the plan for you include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
How long until a moderator replies?:
How can I view my private messages between myself and a Community Moderator?
