4G
05-12-2023 11:44 AM
I changed my plan to the 4g from 3G over a week ago and I can no longer use my data. I can barley use IMessage or any apps on my phone. I wanted t to switch back to the 3G plan but it no longer exists. I have restarted my phone, reset my network setting and have taken o
05-12-2023 02:49 PM
HI @jennabeau before you change it back to 3G plan, I think you still have days with the current 4G plan cycle, just open ticket with support and have them to check the account for you. They can make it work
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
05-12-2023 02:35 PM
If everything worked well on the 3G plan, the switch to a 4G plan should only make it better as you're still using the same network but with a higher speed limit. Since you've run into troubles, I suspect something may have gone wrong during the plan switch and you'll need to contact customer service to sort out their system for you.
05-12-2023 01:46 PM
Everything worked with 3G no issues.
I do not have another phone to test it in.
05-12-2023 12:55 PM
@jennabeau Data worked before you change your plan from 3G speed plan to 4G speed plan?
do you have another phone to test the data and the sim card? Putting your sim in another phone would force a sim re-provision and could resolve the data problem. Please check if you have another phone to test
05-12-2023 12:48 PM
Safari and email do not work. apps never work and imessage will work at some point but only after I have tried to send the message multiple times.
05-12-2023 12:40 PM
@jennabeau but data generally works? (like internet using Safari or email work?)
if it is an iMessage problem only, could be some settings problem with iMessage
05-12-2023 12:38 PM
My data is on. its touch and go. the apps never work but imessages I normally have to try and resend 4-5 times before they actually do.
05-12-2023 12:03 PM
@jennabeau LTE = 4G , just a different name by different phones
So, you cannot use data at all? do you have data enabled? or do you have data disabled/enabled by app? please check and confirm
05-12-2023 11:59 AM
I have over 10GB of data left. my phone still says LTE it never changed to 4G. I already reset all network settings and it didn't fix the problem.
05-12-2023 11:52 AM
@jennabeau you cannot the use the data, but did you login to My Account to confirm if you have any data left?
Please login My Account using Incognito mode first, check the overview page and see if any data left
Also, can you confirm your Preferred network type to LTE and not 5G? Leaving it for 5G will actually cause problem.
You might want to click Reset all networks and it should fix it (but please not that will also delete your saved Wifi, you just need to re-join the Wifi)
Let us know if it works
