4G plans
Coolhandloo_099
If I get a 4G plan will it change in 90 days... Will the price remain the same, will the gigabites change after 90 days???
@Coolhandloo_099
Remember not all plans have 90 days option
Since you are talking about 4G , at this time, the only 4G plan has the 90 days option is the $39/20GB plan and it becomes $34/cycle if you sign up for 90 days.  (and you will need to pay $102 upfront and PM will load all 60GB data for you for you to use during the 90 days)
You can also choose other 5G plans with 90 days option:
$55-50GB or $65-50GB Canada-US plans, they both have $5 off per 30 days if you choose 90 days option
choding_guelph
yes, PM give you date every 90 days and you have to pay every 90 days. you mentioned 20gig with monthly(30days) plan is 60gig with 90 plan. the only difference 90 days price is cheaper than monthly plan.
DDM69
Which plan are you looking at?
The plan will not change in 90 days.  Price will remain the same.  All data is given up front on 90 day plans.
dust2dust
There's no known time limit to the plan or features. The company can do anything it likes anytime they like but it's exceedingly rare that they change rates and features.
