04-25-2023
11:42 AM
04-25-2023
10:11 PM
computergeek541
Presently Public is promoting the 4G. I have the Canada wide and USA calling feature. Can I add 4G to that plan?
Thanks
04-28-2023 11:06 PM
@Tsawwassen wrote:You need to switch to a suitable 4G plan. In order not to lose your existing plans features and time left - would suggest that you select a plan of your choice and click on switch on next renewal date.
That isn't an option because as previously mentioend, the current 4G plans don't include US long distance.
04-28-2023 11:14 AM
04-25-2023 12:27 PM
Since you've obviously been here for a while you will most likely have picked up all the freebies that this place has been giving away for the last few years. There was a long distance freebie included each time. That allows calling to the US. That and the 1000 minute add-on when you run out of those.
If you have the old roaming plan then that would be lost. That's a greater loss as then you would need to buy roaming add-ons that only last 15 days.
So it's not a bad loss if it's just long distance calling. It's a greater loss if you have roaming.
04-25-2023 12:09 PM - edited 04-25-2023 12:10 PM
To get US calling, you need to purchase a US Roaming Add-on before you head down to the USA.
If you are in Canada calling to the USA, you will need a LD calling Add-on.
All PM plans are Canada wide calling and text while in Canada with the 3G or 4G plans.
04-25-2023 11:45 AM
@Sigthunder no you cannot
All current plan does not have US calling
if you move to any of the current plan, you will loss your US calling for free.
However, you might consider workaround of using VoIP app TextNow to call US for free instead
04-25-2023 11:44 AM - edited 04-25-2023 11:46 AM
You actually have to switch to 4G plan (any one offered by PM).
3G/4G are features of a particular plan.
None of current plans offer USA calling. USA calling is done trough US add-on you buy when you need it.
If you have OLD plan (grandfathered) including USA calling AND you have to have USA calling then do not switch to any available plans.
