11-20-2016 03:00 AM - edited 01-05-2022 12:42 AM
I have received my Sim Card but the $40 plan is removed from website, How can I get it?
11-21-2016 01:16 AM
11-20-2016 04:42 PM
I ported two phones from Telus pay as you go to Publicmobile and filled out all of the fields on the activation page, the account and pin and everything and they both binged and sent text messages before I had finished reading the summary page at the end of activation. So maybe 30 to 40 seconds.
I hadn't even gotten to taking the existing telus sim card out and putting the Publicmobile one in and it had already sent a text message with my new Publicmobile PIN that I had set during activation.
11-20-2016 03:48 PM
@aip0401 wrote:Yup, all iPhones work on PM. This is because PM uses the Telus network and Telus has always supported the iPhone.
There very first iPhone model is not compatible as it was not 3g compatible.
11-20-2016 05:14 AM
It takes anywhere from some minutes to days, depends on how busy both sides are.
11-20-2016 04:51 AM
Usually how long it takes for porting?
11-20-2016 04:25 AM
11-20-2016 04:00 AM
Iphone is ok as long as its unlocked.
11-20-2016 03:45 AM
11-20-2016 03:43 AM
If the iPhone is not from Wind, you should be okay
You can use this web site to check your phone
11-20-2016 03:24 AM
publice mobile is gonna work on iphone 4s? unlocked
11-20-2016 03:19 AM
11-20-2016 03:18 AM
11-20-2016 03:16 AM
what's the difference between setting up account from this link https://activate.publicmobile.ca/ and from https://selfserve.publicmobile.ca/self-registration/
11-20-2016 03:15 AM
If you're not with Koodo / Telus, there should be any problems. Just make sure you use the same email for both registration and for the community.
11-20-2016 03:13 AM
11-20-2016 03:12 AM
I was never with Koodo/Telus
11-20-2016 03:11 AM
You should be using the same account for community and sign up to ensure that you get your rewards awarded properly.
You may have a problem if the email is the same as Koodo Self Serve email
11-20-2016 03:10 AM
whe I try to create account from this link https://selfserve.publicmobile.ca/self-registration/
it say's "The phone number entered is invalid or you may have created your profile already"
11-20-2016 03:08 AM
11-20-2016 03:07 AM
@ora wrote:Thanks for quick reply.
I have another question, the account I have created for community can be used to sign up?
The account is separate from your community/forum account. You have to choose an e-mail (if porting from TELUS choose a different e-mail than what you were using for your TELUS account), password, and PIN.
11-20-2016 03:06 AM
They only took it off the main website because new users won't get sim cards in time. But you can still get the fall offer during activation.
When you get to the plans page there are a bunch of columns. Choose the 90-day, province-wide, unlimited text, 12GB and then the "fall promo" gets automatically selected in the last column, showing the total of $120 for the 90 days.
11-20-2016 03:06 AM
11-20-2016 03:06 AM
You won't see it until you register your SIM card and select the options listed by Rockdaddy22
11-20-2016 03:02 AM
