12-28-2023 01:54 PM - last edited on 12-28-2023 05:34 PM by computergeek541
I just signed up for 50gb for $40 on Dec 5. Now 75gb is available. I would like to be able to take advantage of that.
12-28-2023 08:08 PM
Thank you all for your helpful advice. I decided to pay the extra 10 bucks and double my data to 100gb. Once again, thank you this is a wonderful community.
12-28-2023 03:23 PM
Yes, was 5G, 40GB at $34. Now is 75GB at $40/mo
12-28-2023 03:18 PM
That's the way for a positive resolution asap, correct.
12-28-2023 03:11 PM
@canirolf1 They will ? Did they do it for you . What plan were you on and what plan did you get ? @canirolf1
12-28-2023 03:09 PM
Best way to have it contact customer service, they will fix it away
12-28-2023 02:49 PM
12-28-2023 02:47 PM
$39 for 50?? it was $39 for only 40GB earlier , right??
12-28-2023 02:45 PM
@golfball I think it was gone yesterday, I didn't realize it was back until computergeek pointed it out in another thread this morning. The $39 for 50GB at 4G speed is there for existing customers too although the 60GB for $40 seems a better deal to me, with the $2 in points that makes it effectively $38. I don't like having to log in to the account to see what is offered to existing customers, just have to be very careful where I touch the screen lol!
12-28-2023 02:08 PM
All good me to when not on website it’s unclear always have to check in account sometimes there special exclusive offers there for us that never get posted on website
12-28-2023 02:07 PM
I see that now, I was pretty sure it was gone yesterday.
12-28-2023 02:04 PM - edited 12-28-2023 02:07 PM
@golfball Check in your account @golfball its still there @Phil_Adelphus is correct 60GB for $40 5G unlimited data
add 100GB for $50 there still to
12-28-2023 02:03 PM - edited 12-28-2023 02:05 PM
Edit: Nevermind, I was mistaken.
12-28-2023 02:01 PM - edited 12-28-2023 02:01 PM
@Kent5 Yikes sorry this plan only for new activations only not existing customers cell companies move quickly with new plan offerings maybe you have some luck asking support
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
i was on 40GB for $34 and saw the 50GB for $34 so just created new account with new email to get my plan of choice
12-28-2023 01:58 PM
@Kent5 It's for brand new activations only unfortunately, although it only says that if you tap on it for the next page. You can still get the $40 for 60GB unlimited 5G plan but if you do make sure to select change on renewal and not change now or you will forfeit the rest of your existing plan.
12-28-2023 01:58 PM - edited 12-28-2023 01:59 PM
That plan is for new activations only. You can try contacting customer support by sending a message to @CS_Agent to see if they can switch you over, otherwise you have to create a new account.
