3GB data for free
07-31-2020 10:30 AM - edited 01-05-2022 12:20 PM
07-31-2020 11:06 AM
That was back at the end of May we are now at the end of July, is it possible that you have used it up? It is a one time bonus not every 30-day bonus.
07-31-2020 10:45 AM
@ali3azawi wrote:Yes I did.
Then you will need to contact moderator/PM employee to help fix the issue. Please see my first post on how to contact moderator.
07-31-2020 10:41 AM
Yes I did.
07-31-2020 10:38 AM - edited 07-31-2020 10:39 AM
Did you check the terms and conditions ? Usually there is a timeframe when you receive the extra data.
07-31-2020 10:38 AM
Did you meet all of the requirements?
See terms and conditions:
Terms and conditions
* Offer available from May 26 2020 - May 28 2020 at 11:59PM ET to new customers who activate online using the promo code and email entered online by June 12 2020.
3GB one-time data bonus will automatically be applied to activations on $25/mo rate plans or more after the eligible promo code has been entered online. Bonus data will expire if the account becomes inactive or the rate plan is changed.
Please note it may take up to 2 business days for bonus data to be applied.
If you did meet the requirements, then you can contact moderator to help.
To contact moderator via 2 methods:
- Ticketing system - faster response time
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
or
2 Send a private message to moderator through the following link :
