3G to 4G upgrade
11-21-2022 06:55 PM
Hey I see you can upgrade to 4G -15GB for $40 in plan details on sign in page,is this correct?
Also, if so any around a 4G special from 3G to smaller gig plans like a $30 -7GB deal, I only have $25-1GB plan and rarely need more so I wasn’t to go to $40 a month when even a 5GB plan would suit though not looking to go $35-$40.
Thoughts?
Plans
11-21-2022 08:59 PM
I did the same. 15GB for $40 (minus rewards) is pretty good imo
11-21-2022 08:10 PM
@Scamp I was on the $25 plan and jumped on the $40 plan. I don't use much data either but it seems like good value, unless something better comes along.
Consider how a few months ago there was 20GB plan promotion for $55, and it's dropped down to $45 (I assume for a limited time).
11-21-2022 07:06 PM - edited 11-21-2022 07:06 PM
@Scamp Keep monitoring things.. who knows what’s coming or going
11-21-2022 07:01 PM
@Scamp Yes those plans are good if you need lots and lots of data, but seems like PM isn't much interested in offering extra data on the lower priced plans.
11-21-2022 06:59 PM
I have been here a couple of years and the 15 GB and 20 GB limited plans are the best I have seen for existing customers. Great if you need the data. If you do not then save your money. I think that we are all on Public Mobile for the savings.
