$39 for 20GB on old loyalty system
ellenanddavid1
Hi All,
Currently on $40 for 15GB with the old loyalty rewards I see the $39 for 20Gb is now available. Can I switch and remain on the old loyalty rewards system. I know I would have to say to change at new billing cycle and not right away. Please let me know. Thanks so much!
@ellenanddavid1  Yes you will get to keep the holiday bonus too
ellenanddavid1
Thanks for the info @Handy1 any ideas if the holiday bonus data and Long Distance minutes stay in tact as well?
When I went from 1GB to 15GB it stayed the same. Just want to ensure it will when I jump to the 20GB plan.
Thanks!
@_sal_  That’s for promotions Those you will lose , but op asking about old loyalty rewards thise you get to keep
_sal_
Are you guys sure, when I went to do the same I got this message at checkout
"After changing your plan, your current promotions will no longer be valid. Additionally, data add-ons associated with your current subscription may become incompatible if you change your subscription."
What promotions are they referring to? How do we know these aren't the old loyalty rewards we are getting?
Thanks if anyone can clarify this.
@ellenanddavid1  Yes you will keep old rewards I just made this switch myself
Hi @ellenanddavid1   Yes, you can stay on old reward.  Changing plan WON'T affect your rewards system
