01-10-2025 10:58 PM
The description for the 35CAD plan states it is for Quebec residents only. I live in BC. Can I purchase and use it for 35CAD in BC?
01-11-2025 07:05 AM
@YuriiV It sounds like you are looking at the fine print, the "offer details"? For that you need to look for the little numbers or symbols beside each item in the details and then match it up to those shown on the actual plan. For example, there is a + before the note about Quebec only in the offer details, but there is no corresponding + shown on the plan, therefore that item does not apply to that plan.
01-10-2025 11:27 PM
I live in BC too and I can see available, a $35 plan (50GB Data within Canada, US and Mexico..plus talk and text in Canada US and Mexico). If you currently have a plan of higher cost, you won't see this plan as available to you. Just log in to your account and look at your plan menu to confirm...whatever plans you see there, you can change to.
01-10-2025 11:04 PM
@YuriiV
No that plan is only for Quebec residents. When you log in you will not see this plan in your account unless you have a Quebec postal code/address on your account.
01-10-2025 11:04 PM
Hi,
When you’re on the website/app, check the top right corner, make sure the province displays BC, I recommend checking on the app and screenshot it. If it shows for BC province, then it is available.
