11-12-2022 03:36 PM
I have 2 phones i pay for on separate plans.
my ID was stolen so updated my new info. Now only 1 phone is working
11-12-2022 08:01 PM
Login to your 2 separate accounts and see if they are both Active.
11-12-2022 06:51 PM
How can your ID be stolen? Are you saying somebody guessed your email and password for PM??? What anybody could gain having access to your PM account? Hard to believe...
11-12-2022 03:38 PM - edited 11-12-2022 07:09 PM
@prattd so, you cannot find the id to login your 2nd account or cannot receive the 2FA code on that email? In this case, you will need to open ticket with PM support to change to another email login
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
