$25 plan
Pete007
I ask an agent for an answer.  What a useless system!!!
Simple question.  If I have autopay on the $25 plan do I have 500 Mb or 1000Mb??
16 REPLIES 16
@jib_tech wrote:
1GB=1024MB Just saying.
 @jib_tech : Absolutely correct in the common computer parlance. I think the earlier replies of the 1000 were to go along with the question. But dare I bring up Mebi/Gibibyte? 🙂
jib_tech
pkaraa
~1 GB of data in $23 with autopay.
My account -> overview tab will give the details.
@Pete007 wrote:
Why does my phone show 500Mb warning then??  With one day left.
Was the warning from the device itself or was it text from SMS?
if it is warning from phone, you can modify the warning threshold and make sure the cycle start date is correct  (PM running on 30 days cycle while phone default data tracker running on monthly cycle)
if it is a text from PM, it's known to be unreliable.  Best is to confirm your usage on My Account , Overview tab
0PX9O4
@Pete007It's possible the warning you're referring to is a setting on your phone, which is completely independent of your Public Mobile service or account.
@Pete007
for more information about Managing Your Data Usage visit  Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges,
Pete007
Thanks
Pete007
Thanks
JK8
Log into self service and look under My Data & Add-Ons. What does that counter say?
Triguy
You will get 500 MB.  If you signup for autopay then you would get an additional 500 MB.
https://www.publicmobile.ca/en/on/plans#plans-start
Pete007
@Pete007
For $25
  • 500 MB Data¹ at 3G speed
  • +BONUS 500 MB with AutoPay they totals 1GB
  • Unlimited Canada-wide minutes
  • Unlimited International Text and Picture Messaging
dabr
@Pete007   With autopay enabled you have 500 + 500MB plus the $2 autopay reward/discount every 30 days.
Yummy
You will have 1GB of data. Default is 500MB and with autopay additional 500MB.
 @Pete007 : simple answer: 1000 MB.
JK8
You have a total of 1000 MB.
