07-19-2018 10:47 AM - edited 01-04-2022 06:29 PM
Does the $25 90 day plan come with any Minutes/texts/data?
07-19-2018 07:34 PM
@Acekiller wrote:You just need to pay $10/90 days if you are only looking to keep the account open.
@Acekiller I think you mean to say $10/30 days not 90.
07-19-2018 06:00 PM
07-19-2018 12:20 PM
@dna2016 wrote:Hi MeCasa,
The $25 90 day plan is just a dormant plan, in essence it just gets you a number, or if you're porting it's a way to store your number. If you want to be able to actually use the network for calls, texts, data then you'd need to add those features for additional costs. So technically the $25 90 day plan isn't really a plan.
It is impossible to create, or change to, a plan with just the base fee ($25 for 90 days, $10 for 30 days). It is not a way to store your number; the only way to store a number is outlined here: Extended Absence.
07-19-2018 11:15 AM - edited 07-19-2018 11:15 AM
Hi @MeCasa,
07-19-2018 10:48 AM
The $25 fee is just for the line
You need to add something (txt/mins/data) to it
You can not pay just the $25 / 90 days
