12-06-2022 04:09 PM - edited 12-06-2022 04:09 PM
Both my wife and I just switched from another service provider to the 25.00$ 3G plan advertised on the Public Mobile website where it clearly states the following:
Yet, we both got the same plan purchase confirmation email stating that the plan only has 500MB data:
I logged a ticket but have yet to hear from Public. Anyone have a suggestion as to what we can do at this point?
Plans
12-06-2022 06:39 PM
Yes I think definitely less service from reps compared to others or the time involved in submitting ta ticket and waiting for them to get back to you is most likely to be the most annoying part if something goes wrong.
I don't mind some of these things as long as my service doesn't suffer too many glitches and so far I don't have anything to complain about and only needed to contact the reps once for a non service issue.
12-06-2022 06:18 PM
12-06-2022 06:16 PM
That long a wait to update important information isn't really a good way to go about doing business. I expect there's less resources available for public mobile to spend on keeping everything up-to-date as it is a budget carrier.
12-06-2022 05:51 PM
Agree @statusquo
However, at the rate things happen around here, it should take them another 8 to 12 months to update that.
12-06-2022 05:47 PM
Thank you and that would explain it then but now public mobile should update the template if it no longer applies for this plan.
12-06-2022 04:40 PM - edited 12-06-2022 05:52 PM
@statusquo @mathieuff it is an old template. the plan used to be 500 Mb only and an additional 500Mb with Autopay enabled. Since summer, PM has made it easier, there is no longer the need of Autopay to get the full 1Gb, PM just set the 1GB as a standard now, .except in many places , PM still using old templates here and ther
12-06-2022 04:15 PM
I see where your confusion comes from as the screenshot only shows 500MB data and not 1GB as expected in your plan. It must be some sort of an error.
12-06-2022 04:14 PM
@mathieuff glad to hear 😁
12-06-2022 04:11 PM
Apparently Public replies by private message here and not by email or text like I was expecting. The issue is resolved! 😀
12-06-2022 04:11 PM - edited 12-06-2022 04:17 PM
@mathieuff hi it comes with 1 gig per cycle that is an old template that they are using in their welcome email
