240 GB rewards
04-02-2024
02:33 PM
04-02-2024
08:06 PM
computergeek541
I have received a message a couple of weeks ago saying that the 240 GB rewards were added to my account... which I confirmed after logging in.
Today I am surprised to see they are not there anymore...
Did anyone have the same issue?
Add-Ons
04-02-2024 02:38 PM
If you change your plan loyalty bonus is removed
04-02-2024 02:35 PM
if you change your phone plan to a cheaper one, then the promo will disappear. Otherwise you should submit a ticket to resolve the issue if it is not showing on your account
04-02-2024 02:34 PM
Hi @NourChe
did you downgrade your plan? if so, it will be removed as saidin the FAQ of the announcement
if you didn't downgrade, check again using Incognito/private/secret mode on your browser. Or check if agent if you still have question. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
