Paid for service that wont work and there is no support at all
leiknz
I would like a refund because i cannot use the service and i was lied to about it being readily available for me and i cannot even get in touch with anyone from support or a live agent I've been trying for a few days now and nothing works at all. I cant even contact a live agent every time i try it says no one is available.
leiknz
Thank you very much, after a few days of trying to submit a ticket this finally worked!
HI @leiknz
what was the issue? esim installation? or porting?
Share your problem and maybe just one more step
if you really want to get refund or ask support to help,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
fixin
@leiknz - Please submit a ticket here:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
@leiknz
For support from staff, click on the Chat icon and type in Submit a Ticket and outline your issue.
But first, did you download the PM app to activate your SIM?
If you are porting your old number to PM, did you reply to the text with YES with the old SIM in your phone?
More detail is needed to help you further.
