4 hours ago
I've tried restarting, airplane mode, changing settings etc. My partner has activated a number at the same time on their phone which works, we have swapped sims and have determined the issue is with my Sim / number, not the phone as their Sim works in my phone.
I messaged support with no response yet, the chat ai is useless.
Where to go now?
3 hours ago - last edited 3 hours ago
@MordFustang Support hours are 9 a.m. to 10 p.m. eastern time so hopefully you will get a reply soon if you haven't already. Make sure to check your inbox, either envelope icon top right or tap your avatar for Messages.
