Can't access account
momma3bear
I set up 3 accounts. One for myself, my son and daughter. The issue is with my daughters account. For some reason when I signed in after recovering using her phone number it is treating her account as new and I can not get to her actual account. I can't cancel or make changes to her service. I'm at my wits end. Can I just cancel payments at credit card and go somewhere with actual customer service?
9 REPLIES 9
Hi @momma3bear, Is the service continuing to work, calling, text, data (if included in plan)?
I would try uninstalling the Public Mobile app from the phone, restart the phone and try re-installing the app again.
If this does not help I honestly don't know what else to suggest other than to open a new ticket with the CS_agent as there must be something they can do on their end. Hopefully the service is still working but I can see the frustration of not being able to access the account to manage it self-serve as it is intended to be. What type of phone is having the issue?
momma3bear
None of these things have worked.
@CS_Agent wrote:
Hi momma3bear,
Due to no response after 24 hours, this interaction is being closed automatically.
Remember in case you have more questions you can always reach us through the community or chatbot SiMon on the following links:
Chatbot SIMon:
https://www.publicmobile.ca/en/on/get-help
Public mobile community:
https://productioncommunity.publicmobile.ca/t5/Public-Mobile-Community/ct-p/Public_Mobile_Community
Carlos
Customer support agent
@Carlos_T @Carlos_F @carlos_d @Carlos_Z
I'm not sure which CSA posted the above quoted post, but this message thread isn't a a support ticket, nor is this a private message being sent to any specific customer.
CS_Agent
Customer Support Agent
Hi momma3bear,
Chatbot SIMon:
Carlos
@momma3bear  For customer service open a ticket at the chat icon bottom right of this page.  If that doesn't work then send agents a private message using this link
Make sure to check the envelope icon top right for a reply, or tap your avatar to the right of the bell icon for Messages if your device doesn't show an envelope.
momma3bear
Her phone works and the charge is going to my credit card?
momma3bear
I've tried both and when I got in all the account information is gone and it's trying to sell me a new subscription.
Terryscell
Is it possible to try "Forgot Password"?
eddieO
@momma3bear are you trying through the PM app? Is so try going into your phone's settings, select the PM app and clear data then try going back in
You can also try going into her account through the website. If you have been using the website try clearing the website cache or going incognito
