1GB free giveaway
12-16-2019 10:08 AM - edited 01-05-2022 08:33 AM
12-16-2019 10:13 AM
The data speed would be the same as your plan data speed. If you don't have plan data then it would be 4G.
12-16-2019 10:12 AM - edited 12-16-2019 10:13 AM
@PS_PM wrote:On December 4/2019, I was sent a text saying that you were giving me 1GB of free data and international calling.
Would this be 3G LTE or 4G LTE data?
Data here is all LTE. But most data offerings are throttled down to 3mbps. They call it 3G.
Interesting question though. If you're on an older LTE plan or the $30 data-only plan with full LTE data then these add-ons _should_ come to you as full LTE.
Edit: welcome back Dunkgirl.
12-16-2019 10:11 AM - edited 12-16-2019 10:19 AM
@PS_PMYou need to log into self serve and go to add-ons and purchase it (add it onto the account) for $0.
As for the speed, I would imagine its the same speed as your existing plan, if no plan data is on your plan it should be LTE, but I am not sure.
edit- Yes.
"Data Add-Ons to supplement a Data Plan will be provisioned at the data speed selected in your plan. If you have a Talk and/or Text Plan only with no data, the Data Add-Ons available to you will be defaulted to 4G LTE speed."
