Sun card
louisl
Hello i would change the Sim card to esim if not shipped yet and get credit of $10 paid for sim card since esim is free at subscription. My phone is a umidigi A13 pro
Edit by Dunkman: removed personal information
louisl
Thank you
slusagm
Remove the IMEI immediately, you are posting this to the Internet and it is dangerous
To see if you can change to esim at this moment, ask PM directly
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
CS_Agent will reply to your community inbox, check here:   https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
hairbag1
@louisl
you need to download the Public Mobile app to your cell, create your account and buy an esim...they can let you know if yours will take the PM esim.
